[GRASS-dev] wxvdigit
Mohammed Rashad mohammedrashadkm at gmail.com
Wed Sep 29 08:12:09 EDT 2010
How can I communicate with wx digitizer ( i mean using the wxdigit.so file)
using a c++ program.
All I need is create an map with one point from a c++ program which is
linked to _grass6_wxvdigit.so located in
/usr/local/grass-6.5.svn/etc/wxpython/vdigit.
How to access the functions of the library using a C++ program run from
grass shell with all variables set. My program renders a map when run from
grass shell. Now I want to add
digitzer;
Rashad
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100929/a440a159/attachment.html
