[GRASS-dev] after compiling GRASS ,
sunil
sunilrajkiran at gmail.com
Thu Sep 30 01:37:52 EDT 2010
the following compilation log came , , can u explain what should i do next
GRASS GIS compilation log
Started compilation: Wed Sep 29 11:21:01 IST 2010
Errors in:
/usr/local/src/grass-6.4.0/lib/gis
/usr/local/src/grass-6.4.0/lib/gmath
/usr/local/src/grass-6.4.0/lib/linkm
/usr/local/src/grass-6.4.0/lib/driver
/usr/local/src/grass-6.4.0/lib/pngdriver
/usr/local/src/grass-6.4.0/lib/psdriver
/usr/local/src/grass-6.4.0/lib/raster
/usr/local/src/grass-6.4.0/lib/bitmap
/usr/local/src/grass-6.4.0/lib/btree
/usr/local/src/grass-6.4.0/lib/display
/usr/local/src/grass-6.4.0/lib/db/dbmi_base
/usr/local/src/grass-6.4.0/lib/db/dbmi_client
/usr/local/src/grass-6.4.0/lib/db/stubs
/usr/local/src/grass-6.4.0/lib/db/dbmi_driver
/usr/local/src/grass-6.4.0/lib/db/sqlp
/usr/local/src/grass-6.4.0/lib/vask
/usr/local/src/grass-6.4.0/lib/edit
/usr/local/src/grass-6.4.0/lib/external/shapelib
/usr/local/src/grass-6.4.0/lib/form
/usr/local/src/grass-6.4.0/lib/imagery
/usr/local/src/grass-6.4.0/lib/cluster
/usr/local/src/grass-6.4.0/lib/proj
/usr/local/src/grass-6.4.0/lib/rowio
/usr/local/src/grass-6.4.0/lib/segment
/usr/local/src/grass-6.4.0/lib/vector/rtree
/usr/local/src/grass-6.4.0/lib/vector/dglib
/usr/local/src/grass-6.4.0/lib/vector/diglib
/usr/local/src/grass-6.4.0/lib/vector/Vlib
/usr/local/src/grass-6.4.0/lib/vector/transform
/usr/local/src/grass-6.4.0/lib/vector/vedit
/usr/local/src/grass-6.4.0/lib/sites
/usr/local/src/grass-6.4.0/lib/rst/data
/usr/local/src/grass-6.4.0/lib/rst/qtree
/usr/local/src/grass-6.4.0/lib/rst/interp_float
/usr/local/src/grass-6.4.0/lib/g3d
/usr/local/src/grass-6.4.0/lib/gpde
/usr/local/src/grass-6.4.0/lib/dspf
/usr/local/src/grass-6.4.0/lib/symbol
/usr/local/src/grass-6.4.0/lib/init
/usr/local/src/grass-6.4.0/lib/cdhc
/usr/local/src/grass-6.4.0/lib/stats
/usr/local/src/grass-6.4.0/lib/arraystats
/usr/local/src/grass-6.4.0/lib/ogsf
/usr/local/src/grass-6.4.0/lib/nviz
/usr/local/src/grass-6.4.0/db/drivers/dbf
/usr/local/src/grass-6.4.0/db/drivers/postgres
/usr/local/src/grass-6.4.0/db/drivers/sqlite
/usr/local/src/grass-6.4.0/db/drivers/ogr
/usr/local/src/grass-6.4.0/db/base
/usr/local/src/grass-6.4.0/db/db.login
/usr/local/src/grass-6.4.0/display/d.ask
/usr/local/src/grass-6.4.0/display/d.barscale
/usr/local/src/grass-6.4.0/display/d.colorlist
/usr/local/src/grass-6.4.0/display/d.colors
/usr/local/src/grass-6.4.0/display/d.colortable
/usr/local/src/grass-6.4.0/display/d.erase
/usr/local/src/grass-6.4.0/display/d.extend
/usr/local/src/grass-6.4.0/display/d.extract
/usr/local/src/grass-6.4.0/display/d.font
/usr/local/src/grass-6.4.0/display/d.frame
/usr/local/src/grass-6.4.0/display/d.geodesic
/usr/local/src/grass-6.4.0/display/d.graph
/usr/local/src/grass-6.4.0/display/d.grid
/usr/local/src/grass-6.4.0/display/d.his
/usr/local/src/grass-6.4.0/display/d.histogram
/usr/local/src/grass-6.4.0/display/d.info
/usr/local/src/grass-6.4.0/display/d.legend
/usr/local/src/grass-6.4.0/display/d.linegraph
/usr/local/src/grass-6.4.0/display/d.mapgraph
/usr/local/src/grass-6.4.0/display/d.measure
/usr/local/src/grass-6.4.0/display/d.menu
/usr/local/src/grass-6.4.0/display/d.mon/cmd
/usr/local/src/grass-6.4.0/display/d.mon/pgms
/usr/local/src/grass-6.4.0/display/d.nviz
/usr/local/src/grass-6.4.0/display/d.paint.labels
/usr/local/src/grass-6.4.0/display/d.path
/usr/local/src/grass-6.4.0/display/d.profile
/usr/local/src/grass-6.4.0/display/d.rast
/usr/local/src/grass-6.4.0/display/d.rast.arrow
/usr/local/src/grass-6.4.0/display/d.rast.num
/usr/local/src/grass-6.4.0/display/d.rgb
/usr/local/src/grass-6.4.0/display/d.rhumbline
/usr/local/src/grass-6.4.0/display/d.save
/usr/local/src/grass-6.4.0/display/d.text.new
/usr/local/src/grass-6.4.0/display/d.thematic.area
/usr/local/src/grass-6.4.0/display/d.title
/usr/local/src/grass-6.4.0/display/d.vect
/usr/local/src/grass-6.4.0/display/d.vect.chart
/usr/local/src/grass-6.4.0/display/d.what.rast
/usr/local/src/grass-6.4.0/display/d.what.vect
/usr/local/src/grass-6.4.0/display/d.where
/usr/local/src/grass-6.4.0/display/d.zoom
/usr/local/src/grass-6.4.0/general/g.access
/usr/local/src/grass-6.4.0/general/g.ask
/usr/local/src/grass-6.4.0/general/g.dirseps
/usr/local/src/grass-6.4.0/general/g.filename
/usr/local/src/grass-6.4.0/general/g.findetc
/usr/local/src/grass-6.4.0/general/g.findfile
/usr/local/src/grass-6.4.0/general/g.gisenv
/usr/local/src/grass-6.4.0/general/g.gui
/usr/local/src/grass-6.4.0/general/g.mapset
/usr/local/src/grass-6.4.0/general/g.mapsets
/usr/local/src/grass-6.4.0/general/g.message
/usr/local/src/grass-6.4.0/general/g.mkfontcap
/usr/local/src/grass-6.4.0/general/g.parser
/usr/local/src/grass-6.4.0/general/g.proj
/usr/local/src/grass-6.4.0/general/g.pnmcomp
/usr/local/src/grass-6.4.0/general/g.region
/usr/local/src/grass-6.4.0/general/g.setproj
/usr/local/src/grass-6.4.0/general/g.tempfile
/usr/local/src/grass-6.4.0/general/g.transform
/usr/local/src/grass-6.4.0/general/g.version
/usr/local/src/grass-6.4.0/general/manage/cmd
/usr/local/src/grass-6.4.0/general/manage/lister
/usr/local/src/grass-6.4.0/gui/wxpython
/usr/local/src/grass-6.4.0/imagery/i.ask
/usr/local/src/grass-6.4.0/imagery/i.cluster
/usr/local/src/grass-6.4.0/imagery/i.find
/usr/local/src/grass-6.4.0/imagery/i.gensig
/usr/local/src/grass-6.4.0/imagery/i.gensigset
/usr/local/src/grass-6.4.0/imagery/i.group
/usr/local/src/grass-6.4.0/imagery/i.his.rgb
/usr/local/src/grass-6.4.0/imagery/i.maxlik
/usr/local/src/grass-6.4.0/imagery/i.rectify
/usr/local/src/grass-6.4.0/imagery/i.rgb.his
/usr/local/src/grass-6.4.0/imagery/i.smap/shapiro
/usr/local/src/grass-6.4.0/imagery/i.target
/usr/local/src/grass-6.4.0/imagery/i.pca
/usr/local/src/grass-6.4.0/imagery/i.cca
/usr/local/src/grass-6.4.0/imagery/i.atcorr
/usr/local/src/grass-6.4.0/imagery/i.fft
/usr/local/src/grass-6.4.0/imagery/i.ifft
/usr/local/src/grass-6.4.0/imagery/i.zc
/usr/local/src/grass-6.4.0/misc/m.cogo
/usr/local/src/grass-6.4.0/ps/ps.map
/usr/local/src/grass-6.4.0/raster/r.average
/usr/local/src/grass-6.4.0/raster/r.basins.fill
/usr/local/src/grass-6.4.0/raster/r.bilinear
/usr/local/src/grass-6.4.0/raster/r.bitpattern
/usr/local/src/grass-6.4.0/raster/r.buffer
/usr/local/src/grass-6.4.0/raster/r.carve
/usr/local/src/grass-6.4.0/raster/r.cats
/usr/local/src/grass-6.4.0/raster/r.circle
/usr/local/src/grass-6.4.0/raster/r.clump
/usr/local/src/grass-6.4.0/raster/r.coin
/usr/local/src/grass-6.4.0/raster/r.colors
/usr/local/src/grass-6.4.0/raster/r.composite
/usr/local/src/grass-6.4.0/raster/r.compress
/usr/local/src/grass-6.4.0/raster/r.contour
/usr/local/src/grass-6.4.0/raster/r.cost
/usr/local/src/grass-6.4.0/raster/r.covar
/usr/local/src/grass-6.4.0/raster/r.cross
/usr/local/src/grass-6.4.0/raster/r.describe
/usr/local/src/grass-6.4.0/raster/r.distance
/usr/local/src/grass-6.4.0/raster/r.drain
/usr/local/src/grass-6.4.0/raster/r.external
/usr/local/src/grass-6.4.0/raster/r.fill.dir
/usr/local/src/grass-6.4.0/raster/r.flow
/usr/local/src/grass-6.4.0/raster/r.grow2
/usr/local/src/grass-6.4.0/raster/r.grow.distance
/usr/local/src/grass-6.4.0/raster/r.gwflow
/usr/local/src/grass-6.4.0/raster/r.horizon
/usr/local/src/grass-6.4.0/raster/r.his
/usr/local/src/grass-6.4.0/raster/r.in.arc
/usr/local/src/grass-6.4.0/raster/r.in.ascii
/usr/local/src/grass-6.4.0/raster/r.in.bin
/usr/local/src/grass-6.4.0/raster/r.info
/usr/local/src/grass-6.4.0/raster/r.in.gridatb
/usr/local/src/grass-6.4.0/raster/r.in.mat
/usr/local/src/grass-6.4.0/raster/r.in.poly
/usr/local/src/grass-6.4.0/raster/r.in.xyz
/usr/local/src/grass-6.4.0/raster/r.kappa
/usr/local/src/grass-6.4.0/raster/r.lake
/usr/local/src/grass-6.4.0/raster/r.le/r.le.patch
/usr/local/src/grass-6.4.0/raster/r.le/r.le.pixel
/usr/local/src/grass-6.4.0/raster/r.le/r.le.setup
/usr/local/src/grass-6.4.0/raster/r.le/r.le.trace
/usr/local/src/grass-6.4.0/raster/r.los
/usr/local/src/grass-6.4.0/raster/r.mapcalc
/usr/local/src/grass-6.4.0/raster/r.median
/usr/local/src/grass-6.4.0/raster/r.mfilter
/usr/local/src/grass-6.4.0/raster/r.mfilter.fp
/usr/local/src/grass-6.4.0/raster/r.mode
/usr/local/src/grass-6.4.0/raster/r.neighbors
/usr/local/src/grass-6.4.0/raster/r.null
/usr/local/src/grass-6.4.0/raster/r.out.arc
/usr/local/src/grass-6.4.0/raster/r.out.ascii
/usr/local/src/grass-6.4.0/raster/r.out.bin
/usr/local/src/grass-6.4.0/raster/r.out.gridatb
/usr/local/src/grass-6.4.0/raster/r.out.mat
/usr/local/src/grass-6.4.0/raster/r.out.mpeg
/usr/local/src/grass-6.4.0/raster/r.out.pov
/usr/local/src/grass-6.4.0/raster/r.out.ppm
/usr/local/src/grass-6.4.0/raster/r.out.ppm3
/usr/local/src/grass-6.4.0/raster/r.out.vrml
/usr/local/src/grass-6.4.0/raster/r.out.vtk
/usr/local/src/grass-6.4.0/raster/r.param.scale
/usr/local/src/grass-6.4.0/raster/r.patch
/usr/local/src/grass-6.4.0/raster/r.profile
/usr/local/src/grass-6.4.0/raster/r.proj.seg
/usr/local/src/grass-6.4.0/raster/r.quant
/usr/local/src/grass-6.4.0/raster/r.quantile
/usr/local/src/grass-6.4.0/raster/r.random
/usr/local/src/grass-6.4.0/raster/r.random.cells
/usr/local/src/grass-6.4.0/raster/r.random.surface
/usr/local/src/grass-6.4.0/raster/r.reclass
/usr/local/src/grass-6.4.0/raster/r.recode
/usr/local/src/grass-6.4.0/raster/r.region
/usr/local/src/grass-6.4.0/raster/r.report
/usr/local/src/grass-6.4.0/raster/r.resample
/usr/local/src/grass-6.4.0/raster/r.resamp.interp
/usr/local/src/grass-6.4.0/raster/r.resamp.rst
/usr/local/src/grass-6.4.0/raster/r.resamp.stats
/usr/local/src/grass-6.4.0/raster/r.rescale
/usr/local/src/grass-6.4.0/raster/r.rescale.eq
/usr/local/src/grass-6.4.0/raster/r.series
/usr/local/src/grass-6.4.0/raster/r.slope.aspect
/usr/local/src/grass-6.4.0/raster/r.statistics
/usr/local/src/grass-6.4.0/raster/r.stats
/usr/local/src/grass-6.4.0/raster/r.sum
/usr/local/src/grass-6.4.0/raster/r.sun2
/usr/local/src/grass-6.4.0/raster/r.sunmask
/usr/local/src/grass-6.4.0/raster/r.support/modcats
/usr/local/src/grass-6.4.0/raster/r.support/modcolr
/usr/local/src/grass-6.4.0/raster/r.support/modhist
/usr/local/src/grass-6.4.0/raster/r.support/modhead
/usr/local/src/grass-6.4.0/raster/r.support/front
/usr/local/src/grass-6.4.0/raster/r.support.stats
/usr/local/src/grass-6.4.0/raster/r.surf.area
/usr/local/src/grass-6.4.0/raster/r.surf.contour
/usr/local/src/grass-6.4.0/raster/r.surf.idw
/usr/local/src/grass-6.4.0/raster/r.surf.idw2
/usr/local/src/grass-6.4.0/raster/r.surf.random
/usr/local/src/grass-6.4.0/raster/r.surf.gauss
/usr/local/src/grass-6.4.0/raster/r.texture
/usr/local/src/grass-6.4.0/raster/r.thin
/usr/local/src/grass-6.4.0/raster/r.timestamp
/usr/local/src/grass-6.4.0/raster/r.to.rast3
/usr/local/src/grass-6.4.0/raster/r.to.rast3elev
/usr/local/src/grass-6.4.0/raster/r.to.vect
/usr/local/src/grass-6.4.0/raster/r.topidx
/usr/local/src/grass-6.4.0/raster/r.topmodel
/usr/local/src/grass-6.4.0/raster/r.transect
/usr/local/src/grass-6.4.0/raster/r.univar2
/usr/local/src/grass-6.4.0/raster/r.volume
/usr/local/src/grass-6.4.0/raster/r.walk
/usr/local/src/grass-6.4.0/raster/r.water.outlet
/usr/local/src/grass-6.4.0/raster/r.watershed/ram
/usr/local/src/grass-6.4.0/raster/r.watershed/seg
/usr/local/src/grass-6.4.0/raster/r.watershed/front
/usr/local/src/grass-6.4.0/raster/r.what
/usr/local/src/grass-6.4.0/raster/r.what.color
/usr/local/src/grass-6.4.0/raster/simwe/simlib
/usr/local/src/grass-6.4.0/raster/simwe/r.sim.water
/usr/local/src/grass-6.4.0/raster/simwe/r.sim.sediment
/usr/local/src/grass-6.4.0/raster/wildfire/r.ros
/usr/local/src/grass-6.4.0/raster/wildfire/r.spread
/usr/local/src/grass-6.4.0/raster/wildfire/r.spreadpath
/usr/local/src/grass-6.4.0/raster/r.in.gdal
/usr/local/src/grass-6.4.0/raster/r.out.gdal
/usr/local/src/grass-6.4.0/raster/r.surf.fractal
/usr/local/src/grass-6.4.0/raster/r.out.png
/usr/local/src/grass-6.4.0/raster/r.terraflow
/usr/local/src/grass-6.4.0/raster/r.out.tiff
/usr/local/src/grass-6.4.0/raster3d/r3.cross.rast
/usr/local/src/grass-6.4.0/raster3d/r3.in.ascii
/usr/local/src/grass-6.4.0/raster3d/r3.in.v5d
/usr/local/src/grass-6.4.0/raster3d/r3.gwflow
/usr/local/src/grass-6.4.0/raster3d/r3.mkdspf
/usr/local/src/grass-6.4.0/raster3d/r3.out.ascii
/usr/local/src/grass-6.4.0/raster3d/r3.out.v5d
/usr/local/src/grass-6.4.0/raster3d/r3.out.vtk
/usr/local/src/grass-6.4.0/raster3d/r3.stats
/usr/local/src/grass-6.4.0/raster3d/r3.to.rast
/usr/local/src/grass-6.4.0/raster3d/base
/usr/local/src/grass-6.4.0/vector/v.buffer2
/usr/local/src/grass-6.4.0/vector/v.build
/usr/local/src/grass-6.4.0/vector/v.build.polylines
/usr/local/src/grass-6.4.0/vector/v.category
/usr/local/src/grass-6.4.0/vector/v.class
/usr/local/src/grass-6.4.0/vector/v.clean
/usr/local/src/grass-6.4.0/vector/v.convert
/usr/local/src/grass-6.4.0/vector/v.db.connect
/usr/local/src/grass-6.4.0/vector/v.db.select
/usr/local/src/grass-6.4.0/vector/v.delaunay2
/usr/local/src/grass-6.4.0/vector/v.distance
/usr/local/src/grass-6.4.0/vector/v.drape
/usr/local/src/grass-6.4.0/vector/v.edit
/usr/local/src/grass-6.4.0/vector/v.extract
/usr/local/src/grass-6.4.0/vector/v.extrude
/usr/local/src/grass-6.4.0/vector/v.generalize
/usr/local/src/grass-6.4.0/vector/v.hull
/usr/local/src/grass-6.4.0/vector/v.info
/usr/local/src/grass-6.4.0/vector/v.in.ascii
/usr/local/src/grass-6.4.0/vector/v.in.db
/usr/local/src/grass-6.4.0/vector/v.in.dxf
/usr/local/src/grass-6.4.0/vector/v.in.region
/usr/local/src/grass-6.4.0/vector/v.in.sites
/usr/local/src/grass-6.4.0/vector/v.kcv
/usr/local/src/grass-6.4.0/vector/v.kernel
/usr/local/src/grass-6.4.0/vector/v.label
/usr/local/src/grass-6.4.0/vector/v.lrs/lib
/usr/local/src/grass-6.4.0/vector/v.lrs/v.lrs.create
/usr/local/src/grass-6.4.0/vector/v.lrs/v.lrs.segment
/usr/local/src/grass-6.4.0/vector/v.lrs/v.lrs.label
/usr/local/src/grass-6.4.0/vector/v.lrs/v.lrs.where
/usr/local/src/grass-6.4.0/vector/v.proj
/usr/local/src/grass-6.4.0/vector/v.mkgrid
/usr/local/src/grass-6.4.0/vector/v.neighbors
/usr/local/src/grass-6.4.0/vector/v.net
/usr/local/src/grass-6.4.0/vector/v.net.alloc
/usr/local/src/grass-6.4.0/vector/v.net.iso
/usr/local/src/grass-6.4.0/vector/v.net.path
/usr/local/src/grass-6.4.0/vector/v.net.salesman
/usr/local/src/grass-6.4.0/vector/v.net.steiner
/usr/local/src/grass-6.4.0/vector/v.net.visibility
/usr/local/src/grass-6.4.0/vector/v.normal
/usr/local/src/grass-6.4.0/vector/v.out.ascii
/usr/local/src/grass-6.4.0/vector/v.out.dxf
/usr/local/src/grass-6.4.0/vector/v.out.pov
/usr/local/src/grass-6.4.0/vector/v.out.svg
/usr/local/src/grass-6.4.0/vector/v.out.vtk
/usr/local/src/grass-6.4.0/vector/v.overlay
/usr/local/src/grass-6.4.0/vector/v.parallel2
/usr/local/src/grass-6.4.0/vector/v.patch
/usr/local/src/grass-6.4.0/vector/v.perturb
/usr/local/src/grass-6.4.0/vector/v.split
/usr/local/src/grass-6.4.0/vector/v.qcount
/usr/local/src/grass-6.4.0/vector/v.random
/usr/local/src/grass-6.4.0/vector/v.reclass
/usr/local/src/grass-6.4.0/vector/v.sample
/usr/local/src/grass-6.4.0/vector/v.segment
/usr/local/src/grass-6.4.0/vector/v.select
/usr/local/src/grass-6.4.0/vector/v.support
/usr/local/src/grass-6.4.0/vector/v.surf.idw
/usr/local/src/grass-6.4.0/vector/v.surf.rst
/usr/local/src/grass-6.4.0/vector/v.transform
/usr/local/src/grass-6.4.0/vector/v.to.3d
/usr/local/src/grass-6.4.0/vector/v.to.db
/usr/local/src/grass-6.4.0/vector/v.to.points
/usr/local/src/grass-6.4.0/vector/v.to.rast
/usr/local/src/grass-6.4.0/vector/v.to.rast3
/usr/local/src/grass-6.4.0/vector/v.type
/usr/local/src/grass-6.4.0/vector/v.univar
/usr/local/src/grass-6.4.0/vector/v.voronoi
/usr/local/src/grass-6.4.0/vector/v.what
/usr/local/src/grass-6.4.0/vector/v.what.rast
/usr/local/src/grass-6.4.0/vector/v.vol.rst
/usr/local/src/grass-6.4.0/vector/lidar/lidarlib
/usr/local/src/grass-6.4.0/vector/lidar/v.surf.bspline
/usr/local/src/grass-6.4.0/vector/lidar/v.outlier
/usr/local/src/grass-6.4.0/vector/lidar/v.lidar.correction
/usr/local/src/grass-6.4.0/vector/lidar/v.lidar.edgedetection
/usr/local/src/grass-6.4.0/vector/lidar/v.lidar.growing
/usr/local/src/grass-6.4.0/vector/v.out.ogr
/usr/local/src/grass-6.4.0/vector/v.in.ogr
/usr/local/src/grass-6.4.0/vector/v.external
/usr/local/src/grass-6.4.0/vector/v.digit
/usr/local/src/grass-6.4.0/vector/v.label.sa
/usr/local/src/grass-6.4.0/visualization/nviz
/usr/local/src/grass-6.4.0/visualization/nviz2/cmd
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Sep 29 11:47:57 IST 2010
View this message in context: http://osgeo-org.1803224.n2.nabble.com/after-compiling-GRASS-tp5586650p5586650.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
