[GRASS-dev] after compiling GRASS ,
Hamish hamish_b at yahoo.com
Thu Sep 30 02:07:35 EDT 2010
sunil wrote:
> the following compilation log came ,  , can u explain
> what should i do next
> GRASS GIS compilation log
> Started compilation: Wed Sep 29 11:21:01 IST 2010
> Errors in:
> /usr/local/src/grass-6.4.0/lib/gis
here you go:
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Wed Sep 29 11:47:57 IST 2010
for WinGrass see also https://trac.osgeo.org/grass/wiki/CompileOnWindows
Hamish
