[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in
Vect_get_isle_points()
trac at osgeo.org
Sun Apr 3 09:56:37 EDT 2011
#699: v.buffer segfault: in Vect_get_isle_points()
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.buffer | Platform: All
Cpu: All |
Comment(by mlennert):
Replying to [comment:19 mmetz]:
> The most serious bug I am aware of was that cleaning would not work with
the buffer column option, i.e. if different lines/areas are buffered with
different distances. This has been fixed in v.buffer2, but the
implementation in vbuffer2 is both using lots of memory and is very slow.
[snip]
> Unfortunately, everything became a bit more complicated in order to
support a buffer column with individual buffering distances and in order
to handle some special cases.
Just to make sure I understand: so your corrected version of v.buffer
still contains a bug for buffer columns ? Any idea how this bug could be
solved ? Or are you pleading for having a fast v.buffer without buffer
column and maybe an option v.buffer.column based on v.buffer2 which
provides a buffer column option, but runs slower ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/699#comment:20>
