[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Sun Apr 3 10:30:07 EDT 2011
 Reporter:  neteler   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Comment(by mmetz):
 Replying to [comment:20 mlennert]:
 > Replying to [comment:19 mmetz]:
 > > The most serious bug I am aware of was that cleaning would not work
 with the buffer column option, i.e. if different lines/areas are buffered
 with different distances. This has been fixed in v.buffer2, but the
 implementation in vbuffer2 is both using lots of memory and is very slow.
 > [snip]
 > > Unfortunately, everything became a bit more complicated in order to
 support a buffer column with individual buffering distances and in order
 to handle some special cases.
 > Just to make sure I understand: so your corrected version of v.buffer
 still contains a bug for buffer columns ? Any idea how this bug could be
 solved ? Or are you pleading for having a fast v.buffer without buffer
 column and maybe an option v.buffer.column based on v.buffer2 which
 provides a buffer column option, but runs slower ?
 Sorry for being unclear: the buffer column option is working just fine in
 v.buffer. I transferred the method of v.buffer2 to v.buffer and optimized
 the method.
 In my tests, the results of v.buffer/v.parallel are more accurate than
 v.buffer2/v.parallel2 (granted that v.buffer2/v.parallel2 do not bomb
 out); therefore I would plead to replace v.buffer2/v.parallel2 with
 v.buffer/v.parallel.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/699#comment:21>
