[GRASS-dev] Re: [GRASS GIS] #1342: grass.core.find_program()
 problem with ssh and other
    trac at osgeo.org
    Wed Apr  6 16:41:16 EDT 2011
#1342: grass.core.find_program() problem with ssh and other
 Reporter:  lucadelu             |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  7.0.0
Component:  Python               |     Version:  svn-trunk
 Keywords:  python find_program  |    Platform:  Linux
      Cpu:  Unspecified          |
Comment(by glynn):
 Replying to [ticket:1342 lucadelu]:
 > there are some program that print help message to stderr instead stdout
 and this return false instead true in grass.core.find_program().
 Whether the program prints anything to either stream is entirely
 irrelevant; find_program() simply checks the return code.
 In order for find_program() to work, you need to find some invocation
 which returns a zero exit status (indicating success). If running the
 command with --help is considered an error (non-zero exit status), you'll
 need to find some other option. E.g. for ssh, you can use "ssh -V".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1342#comment:1>
