[GRASS-dev] Re: [GRASS GIS] #1342: grass.core.find_program() problem with ssh and other
GRASS GIS trac at osgeo.org
Tue Apr 12 12:43:26 EDT 2011
  Reporter:  lucadelu  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Python    |     Version:  svn-trunk
Resolution:  invalid   |    Keywords:  python find_program
  Platform:  Linux     |         Cpu:  Unspecified
Changes (by lucadelu):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:1 glynn]:
 > In order for find_program() to work, you need to find some invocation
 which returns a zero exit status (indicating success). If running the
 command with --help is considered an error (non-zero exit status), you'll
 need to find some other option. E.g. for ssh, you can use "ssh -V".
 Ok, thanks it works for me
Ticket URL: <http://trac.osgeo.org/grass/ticket/1342#comment:2>
