[GRASS-dev] XDRIVER
roger at spinn.net
roger at spinn.net
Wed Apr 13 14:11:10 EDT 2011
Devs,
I'm aware that XDRIVER is antiquated piece of software that the project does
not intend to use for it's primary display or interactive tool. I have two
main questions (and maybe some to follow up):
Does the project intend to retain XDRIVER in the distribution?
Are there any plans to update or upgrade XDRIVER?
As a bit of background, I use a Tcl/TK GUI for GRASS that I have been
developing incrementally since roughly 1997, so not only is the GUI fairly
well-developed but I'm pretty accustomed to it and I intend to keep it. The
GUI uses XDRIVER as it's primary display and interactive tool and ps.map for
high quality output.
I recently started developing a module that would let me interactively
construct map annotations using points, lines, arrows, rectangles,
polylines, polygons and text. When I started constructing the text
capability I found that R_get_text_box() produced grossly incorrect results.
That compounded the problem with low quality of the screen fonts -- even
using FreeType2.
I remedied the problem by adding libXft to XDRIVER. That gave me
high-quality, antialiased, client-side fonts and replaced all of the
font-handling and rendering capabilities currently in GRASS. And it
enormously simplified the code. And R_get_text_box() produces the right
result.
Adding Xft changed the behavior of some text and font modules: label
placement in d.vect is great, but d.font didn't work and d.paint.labels
references labels incorrectly. There are probably other changes that I'll
find later.
The effort it takes for me to maintain these changes could mean that I am
stuck with my current GRASS version unless I rebuild all of the necessary
changes into every future update. That could become a large effort,
particularly if I go on to add keyboard interaction and a few other changes
that I'm contemplating. Fortunately, GRASS has become pretty stable, so I
don't have immediate problems. The alternative is that -- if there are
enough other users interested -- the project could incorporate some of the
changes in their code base. Is there enough interest to justify that?
Roger Miller
