[GRASS-dev] [GRASS GIS] #1349: Ps.map supports only english
trac at osgeo.org
Tue Apr 19 05:26:33 EDT 2011
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 6.5.0
Component: Ps.map | Version: unspecified
Keywords: encoding | Platform: Unspecified
Cpu: Unspecified |
Postscript file generated by ps.map uses Latin1 and as a result I can't
use czech language properly. I have no experience with postscript, so
would it be possible to change it to utf8?
Another issue relating to other languages is the label of scalebar units.
It would be nice if the user could customize the label. There is a closed
ticket #64 dealing with this problem a bit.
Thanks
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1349>
