[GRASS-dev] Re: [GRASS GIS] #1349: Ps.map supports only english
GRASS GIS trac at osgeo.org
Wed Apr 20 02:55:46 EDT 2011
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  6.5.0
Component:  Ps.map       |     Version:  unspecified
 Keywords:  encoding     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by hamish):
 Replying to [ticket:1349 annakrat]:
 > Postscript file generated by ps.map uses Latin1 and as a result
 > I can't use czech language properly. I have no experience with
 > postscript, so would it be possible to change it to utf8?
 from the help page:
 For users wanting to use special characters (such as accented char-
 acters) it is important to note that ps.map uses ISO-8859-1  encod-
 ing.   This  means  that  your  instructions  file  will have to be
 encoded in this encoding. If  you  normally  work  in  a  different
 encoding  environment  (such  as UTF-8), you have to transform your
 file to the ISO-8859-1 encoding, for example  by  using  the  iconv
 utility:
 iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
 from the mailing list archive:
    http://thread.gmane.org/gmane.comp.gis.grass.devel/15881
 > Another issue relating to other languages is the label of
 > scalebar units. It would be nice if the user could customize
 > the label.
 do you wish to have a translated version of one of the existing distance
 formats, or to use one not on the current list?
 I'd rather have it start from a fixed list of names+conv_to_meter values,
 but translated names of units is possible:
 Index: ps/ps.map/do_scalebar.c
 --- ps/ps.map/do_scalebar.c     (revision 46046)
 +++ ps/ps.map/do_scalebar.c     (working copy)
 @@ -1,9 +1,8 @@
 -/* Function to draw scalebar on page
 +/* Function to draw scalebar on page */
  #include <string.h>
  #include <math.h>
 +#include <grass/glocale.h>
  #include "local_proto.h"
  #include "distance.h"
 @@ -192,15 +191,15 @@
      if (sb.units == SB_UNITS_AUTO)
         strcpy(num, G_database_unit_name(TRUE));
      else if(sb.units == SB_UNITS_METERS)
 -       strcpy(num, "meters");
 +       strcpy(num, _("meters"));
      else if(sb.units == SB_UNITS_KM)
 -       strcpy(num, "kilometers");
 +       strcpy(num, _("kilometers"));
      else if(sb.units == SB_UNITS_FEET)
 -       strcpy(num, "feet");
 +       strcpy(num, _("feet"));
      else if(sb.units == SB_UNITS_MILES)
 -       strcpy(num, "miles");
 +       strcpy(num, _("miles"));
      else if(sb.units == SB_UNITS_NMILES)
 -       strcpy(num, "nautical miles");
 +       strcpy(num, _("nautical miles"));
      text_box_path(72.0 * (x + length/2), 72.0 * (PS.page_height - (sb.y +
 0.075)),
         CENTER, UPPER, num, sb.fontsize, 0);
 I don't think I bothered with that last time, beyond discussing if meters
 vs. metres should be taken from 'g.proj -p'. I'm totally ignorant how and
 if those unit names are called in non-latin languages so didn't take it
 further.
 In general I'm not much of a fan of hard-results depending on the locale
 setting (harms ability to rely on reproducible results), but the above
 patch seems reasonable enough to me.
 does it solve the wish?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1349#comment:1>
