[GRASS-dev] Re: [GRASS GIS] #1349: Ps.map supports only english
trac at osgeo.org
Wed Apr 20 05:12:50 EDT 2011
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 6.5.0
Component: Ps.map | Version: unspecified
Keywords: encoding | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 hamish]:
> Replying to [ticket:1349 annakrat]:
> > Postscript file generated by ps.map uses Latin1 and as a result
> > I can't use czech language properly. I have no experience with
> > postscript, so would it be possible to change it to utf8?
> from the help page:
> For users wanting to use special characters (such as accented char-
> acters) it is important to note that ps.map uses ISO-8859-1 encod-
> ing. This means that your instructions file will have to be
> encoded in this encoding. If you normally work in a different
> encoding environment (such as UTF-8), you have to transform your
> file to the ISO-8859-1 encoding, for example by using the iconv
> utility:
> iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
> from the mailing list archive:
> http://thread.gmane.org/gmane.comp.gis.grass.devel/15881
The problem is that
will not work if the utf_file contains special caracters which are defined
in ISO-8859-2.
I don't know how/if Postscript handles UTF-8. a2ps and enscript can create
Postscript files from text encoded in ISO-8859-2, but they cannot
transform UTF-8 text into Postscript files.
This seems to be a more structural issue than just the iconv conversion. I
don't know how other projects handle this issue.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1349#comment:2>
