[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows fails with "Unable to delete vector map"
GRASS GIS trac at osgeo.org
Wed Apr 20 04:00:32 EDT 2011
 Reporter:  lponti                                                        |       Owner:  grass-dev@…
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.2
Component:  Vector                                                        |     Version:  6.4.0
 Keywords:  wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                   |
Comment(by hellik):
 Replying to [comment:25 mmetz]:
 > Replying to [comment:23 marisn]:
 > > I changed bug summary to better reflect it's scope.
 > > It affects also v.in.ogr removal of temporary files (coor and not hist
 file). Bug #1303
 > Hopefully fixed for devbr in r46041.
 tested with WinGRASS-6.5.SVN-r46045-1-Setup.exe
 g.remove vect=mygeology at user1
 Removing vector <mygeology at user1>
 Unable to delete file 'J:\gisdata/nc_spm_08/user1/vector/mygeology/hist'.
 Reason: Permission denied
 couldn't be removed
 <mygeology> nothing removed
 (Wed Apr 20 09:59:46 2011) Command finished (0 sec)
 (Wed Apr 20 09:59:47 2011)
 (Wed Apr 20 09:59:48 2011) Command finished (0 sec)
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:26>
