[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
fails with "Unable to delete vector map"
trac at osgeo.org
Wed Apr 20 10:09:25 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:25 mmetz]:
> Hopefully fixed for devbr in r46041.
> Vect_delete() uses unlink(), whereas raster and all other files are
removed by remove(): the file will remain in existence until the last file
descriptor referring to it is closed (at least on Linux). In
Vect_delete(), I have replaced unlink() with remove(), working on Linux,
awaits testing on Windows.
I'm fairly sure that r46041 has no effect. On Unix, the difference between
remove() and unlink() is that remove() handles both files and directories;
it calls unlink() for files and rmdir() for directories. unlink() only
works on files.
The "garbage-collecting" behaviour (a file is removed when it has no links
and no process has it open) always applies. There is no way to force
deletion of a file which is open, or to remove all links to a file (there
may exist links in directories on which the process lacks write
permission, in directories which are inaccessible due to having another
filesystem mounted over them, etc).
On Windows, I can't discern any difference between unlink() and remove().
Unlike Unix, remove() only works for files. And unlike Unix, you can't
"unlink" a file which is open; the unlink/remove call fails with EACCESS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:27>
