[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
 fails with "Unable to delete vector map"
    trac at osgeo.org
    Wed Apr 20 10:38:05 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
 Reporter:  lponti                                                        |       Owner:  grass-dev@…
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.2
Component:  Vector                                                        |     Version:  6.4.0
 Keywords:  wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                   |
Comment(by mmetz):
 Replying to [comment:27 glynn]:
 > Replying to [comment:25 mmetz]:
 > > Hopefully fixed for devbr in r46041.
 > > Vect_delete() uses unlink(), whereas raster and all other files are
 removed by remove(): the file will remain in existence until the last file
 descriptor referring to it is closed (at least on Linux). In
 Vect_delete(), I have replaced unlink() with remove(), working on Linux,
 awaits testing on Windows.
 > I'm fairly sure that r46041 has no effect. On Unix, the difference
 between remove() and unlink() is that remove() handles both files and
 directories; it calls unlink() for files and rmdir() for directories.
 unlink() only works on files.
 > The "garbage-collecting" behaviour (a file is removed when it has no
 links and no process has it open) always applies. There is no way to force
 deletion of a file which is open, or to remove all links to a file (there
 may exist links in directories on which the process lacks write
 permission, in directories which are inaccessible due to having another
 filesystem mounted over them, etc).
 > On Windows, I can't discern any difference between unlink() and
 remove(). Unlike Unix, remove() only works for files. And unlike Unix, you
 can't "unlink" a file which is open; the unlink/remove call fails with
 EACCESS.
 None of the files making up a native GRASS vector should be still open
 when they are to be deleted. Some of them may have been opened and closed
 recently (a few lines of code further up in Vect_delete()), but I am
 pretty sure that they are all closed, otherwise g.remove should never
 work. Maybe fclose() does not close a file stream now, but sometime soon
 (e.g. busy flushing buffers), and 'soon' is sometimes too late?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:28>
