[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows fails with "Unable to delete vector map"
GRASS GIS trac at osgeo.org
Thu Apr 21 11:55:51 EDT 2011
 Reporter:  lponti                                                        |       Owner:  grass-dev@…
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.2
Component:  Vector                                                        |     Version:  6.4.0
 Keywords:  wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                   |
Comment(by mmetz):
 Replying to [comment:32 martinl]:
 > Replying to [comment:31 martinl]:
 > > Replying to [comment:30 mmetz]:
 > > > OK. I suggest Vect!__open_old() and Vect_open_new() should
 initialize all file pointers to NULL and Vect_close() should close
 anything that is not NULL.
 > > it's already in trunk [source:grass/trunk/lib/vector/Vlib/open.c#L165]
 > ...only referring to Vect!__open_old()
 Unfortunately, G_zero() does not set all contents of the Map_info
 structure to 0 or NULL; that's the reason for the existence of line 180 in
 open.c [grass/trunk/lib/vector/Vlib/open.c#L180]
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:33>
