[GRASS-dev] [GRASS GIS] #1423: GRASS 6.4.1 won't compile against
FFmpeg 0.8
trac at osgeo.org
Wed Aug 17 23:23:42 EDT 2011
#1423: GRASS 6.4.1 won't compile against FFmpeg 0.8
Reporter: sharpie | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
It appears some symbols used by the GRASS interface to FFmpeg were
depreciated in the latetest FFmpeg release:
/usr/bin/cc
-I/private/tmp/homebrew-grass-6.4.1-BgUk/grass-6.4.1/dist.i386-apple-
darwin10.8.0/include
-I/usr/local/Cellar/readline/6.2.1/include
-I/usr/local/Cellar/gettext/0.18.1.1/include -I/usr/local/include -O3
-march=core2 -msse4.1 -w -pipe -arch x86_64 -I/usr/local/include
-fno-common
-DPACKAGE=\""grasslibs"\" -I/usr/local/Cellar/gdal/1.8.1/include
-I/usr/local/Cellar/geos/3.3.0/include -DPACKAGE=\""grasslibs"\"
-I/System/Library/Frameworks/OpenGL.framework/Headers
-I/usr/local/include/libavcodec -I/usr/local/include/libavdevice
-I/usr/local/include/libavfilter -I/usr/local/include/libavformat
-I/usr/local/include/libavutil -I/usr/local/include/libpostproc
-I/usr/local/include/libswscale
-o OBJ.i386-apple-darwin10.8.0/gsd_img_mpeg.o -c gsd_img_mpeg.c
gsd_img_mpeg.c: In function ‘add_video_stream’:
gsd_img_mpeg.c:69: error: ‘CODEC_TYPE_VIDEO’ undeclared (first use in this
function)
gsd_img_mpeg.c:69: error: (Each undeclared identifier is reported only
once
gsd_img_mpeg.c:69: error: for each function it appears in.)
gsd_img_mpeg.c: In function ‘write_video_frame’:
gsd_img_mpeg.c:218: error: ‘PKT_FLAG_KEY’ undeclared (first use in this
function)
make[3]: *** [OBJ.i386-apple-darwin10.8.0/gsd_img_mpeg.o] Error 1
Full build log attached.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1423>
