[GRASS-dev] trunk r47474 breaks OGSF rendering of points on
surface
Maris Nartiss
maris.gis at gmail.com
Thu Aug 18 02:58:07 EDT 2011
Thanks for fixing.
So - where's the wxNviz code and how to compile it? I'm not following
that closely to all new experimental GUI things and add-ons. It
doesn't seem to be compiled by default on trunk, as wxgui's search
also can not find it:
File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
linux-gnu/etc/gui/wxpython/gui_modules/ghelp.py", line 164,
in OnSearchModule
if self.cmdPrompt.CheckKey(text, data['keywords']):
AttributeError
'GPromptSTC' object has no attribute 'CheckKey'
Maris.
2011/8/17 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/8/17 Maris Nartiss <maris.gis at gmail.com>:
>> If You can give me some info how to test it without nviz, I will do that.
> try out also wxNviz [1].
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
