[GRASS-dev] trunk r47474 breaks OGSF rendering of points on surface
Anna Kratochvílová kratochanna at gmail.com
Thu Aug 18 04:04:45 EDT 2011
On Thu, Aug 18, 2011 at 8:58 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Thanks for fixing.
> So - where's the wxNviz code and how to compile it? I'm not following
> that closely to all new experimental GUI things and add-ons. It
> doesn't seem to be compiled by default on trunk, as wxgui's search
> also can not find it:
It's in G7 in main repository, you can switch from 2D view to 3D view
mode in Map Display combo box (on the right side of it).
Some videos (a little bit outdated):
http://grass.osgeo.org/wiki/WxNviz#HowTo
Man page:
http://grass.osgeo.org/grass70/manuals/html70_user/wxGUI.Nviz.html
You can be interested in nviz_cmd too:
http://grass.osgeo.org/grass70/manuals/html70_user/nviz_cmd.html
Anna
> File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
> linux-gnu/etc/gui/wxpython/gui_modules/ghelp.py", line 164,
> in OnSearchModule
> if self.cmdPrompt.CheckKey(text, data['keywords']):
> AttributeError
> 'GPromptSTC' object has no attribute 'CheckKey'
> Maris.
> 2011/8/17 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> 2011/8/17 Maris Nartiss <maris.gis at gmail.com>:
>>> If You can give me some info how to test it without nviz, I will do that.
>> try out also wxNviz [1].
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
