[GRASS-dev] trunk r47474 breaks OGSF rendering of points on surface
Maris Nartiss maris.gis at gmail.com
Thu Aug 18 05:12:20 EDT 2011
Hello,
hm. OK. As switching to 3D in map display window just closes wxgui
without any messages, I was under impression that it's the same old
non-working code and new code is developed somewhere else.
Bad news for You - it doesn't work at all.
gdb just says: Inferior 1 (process 32514) exited with code 01
valgrind --trace-children=yes reports:
==418== Stack overflow in thread 1: can't grow stack to 0x7fe05fff8
==418==
==418== Process terminating with default action of signal 11 (SIGSEGV)
==418==  Access not within mapped region at address 0x7FE05FFF8
==418==    at 0xAF49CA7: wxMBConv::WC2MB(char*, wchar_t const*,
unsigned long) const (in /usr/lib64/libwx_baseu-2.8.so.0.8.0)
Good luck.
Maris.
2011/8/18 Anna Kratochvílová <kratochanna at gmail.com>:
> Hi,
> It's in G7 in main repository, you can switch from 2D view to 3D view
> mode in Map Display combo box (on the right side of it).
> Some videos (a little bit outdated):
> http://grass.osgeo.org/wiki/WxNviz#HowTo
> Man page:
> http://grass.osgeo.org/grass70/manuals/html70_user/wxGUI.Nviz.html
> You can be interested in nviz_cmd too:
> http://grass.osgeo.org/grass70/manuals/html70_user/nviz_cmd.html
> Anna
