[GRASS-dev] Create new branch from trunk for temporal GIS integration
Martin Landa landa.martin at gmail.com
Mon Aug 22 13:19:07 EDT 2011
2011/8/22 Markus Metz <markus.metz.giswork at googlemail.com>:
> I would try to avoid having yet another branch, three is maybe already
> one too much. IMHO, the most important question is whether we want to
> add the time dimension in GRASS. If this finds sufficient support, I
> would rather opt to modify trunk directly because compatibility will
> be maintained when adding the temporal extension and trunk can be used
> as before. In this case, another branch may cause more trouble than
> good.
> +1 for adding time dimension
bearing in mind the number of active GRASS developers I agree with MarkusM.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
