[GRASS-dev] how to use graphical modeler
Martin Landa
landa.martin at gmail.com
Fri Aug 26 12:21:31 EDT 2011
2011/8/26 Michael Barton <Michael.Barton at asu.edu>:
> I was procrastinating this evening and tried to use the new graphical modeler so I could teach it to others. I was going to try the following work flow:
> vector streams map -> v.to.rast -> raster streams map -> r.buffer -> raster streams buffer map -> r.to.vect -> vector polygons of raster buffers of different buffer distances from the streams
> Unfortunately, I could not figure out how it works. I can create an action (module) box and data (maps) ellipses. But nothing happens when I press the connectors button, except that the cursor turns into a cross.
btw, data items are created automatically when you define them by
action, see [1]. Note that graphical modeler is under development...
Martin
[1] http://grass.osgeo.org/wiki/WxGUI_Modeler#Video_Tutorials
