[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
fails with "Unable to delete vector map"
trac at osgeo.org
Fri Aug 26 14:39:08 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:37 mmetz]:
> So does this mean that the DBMI driver is not properly closed?
It certainly looks that way. Even if the client doesn't send
DB_PROC_SHUTDOWN_DRIVER, the driver should get EOF on its stdin when the
client terminates.
Can you use e.g. Process Explorer and/or gdb to discover anything about
the state of the driver process after the client terminates?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:38>
