[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
fails with "Unable to delete vector map"
trac at osgeo.org
Sun Aug 28 17:33:48 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by lutra):
Hi all, I'm mainly a GRASS user trough QGIS and I would like to underline
that in QGIS 1.5, that was shipped with a GRASS 6.4 RC revision (should
not be hard to check exactly what revision was used), this issue was not
present, I just tested again.
Moreover also this
http://hub.qgis.org/issues/3648
was not present (this is actually a issue that makes GRASS unusable under
QGIS >= 1.6) and that may be was fixed with
http://trac.osgeo.org/grass/changeset/47519
unfortunately is not yet possible to confirm the fix as we still don't
have GRASS svn in the OSGeo4W installer.
Cheers
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:41>
