[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows fails with "Unable to delete vector map"
GRASS GIS trac at osgeo.org
Mon Aug 29 04:24:27 EDT 2011
 Reporter:  lponti                                                        |       Owner:  grass-dev@…
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.2
Component:  Vector                                                        |     Version:  6.4.0
 Keywords:  wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                   |
Comment(by mmetz):
 Replying to [comment:40 glynn]:
 > Can you try modifying lib/db/dbmi_client/shutdown.c to use G_wait()
 instead of _cwait()? _cwait() is only defined as working with process IDs
 returned from the _spawn functions, which are no longer used.
 Using G_wait() instead of _cwait() works for me in trunk with
 g.copy,g.remove and v.in.ogr. G_wait() is not available in 6.4, although
 in 6.4 the _spawn functions have been eliminated as well. Has r42668 been
 an incomplete backport to 6.4? G_wait() has been introduced in trunk with
 r40648, i.e. before the backport to 6.4. Do the small differences in
 lib/gis/spawn.c between trunk and 6.4 really make sense? From your comment
 and my tests I understand that if the _spawn functions are eliminated,
 _cwait must be eliminated (replaced with G_wait()) as well.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:42>
