[GRASS-dev] v.out.ogr exports more features than available
Hamish
hamish_b at yahoo.com
Tue Dec 13 20:50:10 EST 2011
Benjamin wrote:
> Sounds like v.out.ogr includes some
> features in
> the output that are marked "dead" but are still in the
> dataset. Could you check two things, please:
> 2) and make a copy of the cleaned vector points map
> using g.copy vect=, and use v.out.ogr to export
> the copy instead of the cleaned original?
"v.extract cat=1-99999999" might help too.
Hamish
