[GRASS-dev] v.out.ogr exports more features than available
Maris Nartiss maris.gis at gmail.com
Wed Dec 14 01:53:06 EST 2011
Hello,
yes, I used QGIS to verify count of exported features in Shapefile and
indeed count matched with one reported by v.out.ogr as "written
feature count".
And now comes the best - g.copy and v.extract both had NO effect on
result -> resulting dataset still was exported with ALL points present
before v.clean. I run both ways twice to avoid PEBKAC.
And now the worst thing - GRASS 6.4.2 is also affected. I'm opening
ticket and blocking release till we will figure out what's exactly
wrong. If somebody has an idea, I can send dataset off-list for
testing.
Maris.
2011/12/14 Hamish <hamish_b at yahoo.com>:
> Benjamin wrote:
>> Sounds like v.out.ogr includes some
>> features in
>> the output that are marked "dead" but are still in the
>> dataset. Could you check two things, please:
>> 2) and make a copy of the cleaned vector points map
>> using g.copy vect=, and use v.out.ogr to export
>> the copy instead of the cleaned original?
> "v.extract cat=1-99999999" might help too.
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
