[GRASS-dev] Re: [GRASS GIS] #1507: r.in.gdal & others: -e must only modify the current mapset's WIND file
GRASS GIS trac at osgeo.org
Wed Dec 14 09:13:57 EST 2011
 Reporter:  hamish                           |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  blocker                          |   Milestone:  6.4.2
Component:  Default                          |     Version:  svn-trunk
 Keywords:  r.in.gdal, r.external, v.in.ogr  |    Platform:  All
      Cpu:  All                              |
Comment(by neteler):
 When you create a new location (e.g. location wizard) without defining the
 boundaries, you obtain a 0-1 sized location. The use these import tools to
 set the DEFAULT_WIND (not WIND) using the now deleted flag.
 That was the relevant purpose which I still want to use in future
 (on command line, in one step). I disagree that this functionality has
 been removed with a discussion time of less than 48hs.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1507#comment:5>
