[GRASS-dev] Re: [GRASS GIS] #1507: r.in.gdal & others: -e must only
modify the current mapset's WIND file
trac at osgeo.org
Wed Dec 14 09:29:27 EST 2011
#1507: r.in.gdal & others: -e must only modify the current mapset's WIND file
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Default | Version: svn-trunk
Keywords: r.in.gdal, r.external, v.in.ogr | Platform: All
Cpu: All |
Comment(by neteler):
I suggest to revert the changes and reinstate the original behaviour with
the limitation that DEFAULT_WIND can only be modified if the user is in
PERMANENT (warning + only WIND change otherwise).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1507#comment:6>
