[GRASS-dev] grass module execution
Mohammed Rashad mohammedrashadkm at gmail.com
Wed Dec 14 12:07:46 EST 2011
Hi All,
How to run grass module from C++  code.I am coding a small application
using C++ I want to call grass commands from the application (g.gisenv)
this can be done in different ways
1. python using gcmd.RunCommand(..)
2. setup grass environment and execute from c++ code using system command
system("g.gisev");
I dont want to call in these ways.
My requirement is different
I will link all grass libraries with my application.
init grass using g_gisinit(...)
specify a program {g.gisenv}
give the attributes required to the application
execute the function without spawning a new process [ I think its not
possible :(   ]
parse the result.
Display results to user
Any pointers will be much appreciated..
Regards
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111214/cba73e26/attachment.html
