[GRASS-dev] Re: [GRASS GIS] #1507: r.in.gdal & others: -e must only
modify the current mapset's WIND file
trac at osgeo.org
Wed Dec 14 15:50:06 EST 2011
#1507: r.in.gdal & others: -e must only modify the current mapset's WIND file
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Default | Version: svn-trunk
Keywords: r.in.gdal, r.external, v.in.ogr | Platform: All
Cpu: All |
Comment(by hamish):
we have a couple of choices on how it should work:
if not in PERMANENT:
* extend current WIND + newly imported map
if in PERMANENT:
* extend DEFAULT_WIND + newly imported map
then
* stop
or
* extend WIND + newly imported map
or
* replace WIND based on extended DEFAULT_WIND + new map
in all cases a message will be output stating what has happened.
so when you're in PERMANENT both WIND and DEFAULT_WIND would get updated.
but then should WIND and DEFAULT_WIND expand independently, or is it
reasonable to just write out the newly expanded DEFAULT_WIND and
completely replace PERMANENT's WIND? (this is how 'r.in.gdal -e' is
currently coded in trunk)
any preference on how this should work?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1507#comment:10>
