[GRASS-dev] Re: [GRASS GIS] #1507: r.in.gdal & others: -e must only modify the current mapset's WIND file
GRASS GIS trac at osgeo.org
Thu Dec 15 10:19:25 EST 2011
 Reporter:  hamish                           |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  blocker                          |   Milestone:  6.4.2
Component:  Default                          |     Version:  svn-trunk
 Keywords:  r.in.gdal, r.external, v.in.ogr  |    Platform:  All
      Cpu:  All                              |
Comment(by glynn):
 Replying to [comment:10 hamish]:
 Updating WIND only makes sense if the next step is to copy WIND to
 somewhere more permanent (either DEFAULT_WIND or a named region).
 This opens up the issue of whether individual mapsets should have a
 DEFAULT_WIND. Or, alternatively, whether "g.region -d" and "g.region -s"
 should be synonyms for e.g. "g.region region=default" and "g.region
 save=default" respectively (with the former falling back to
 ../PERMANENT/DEFAULT_WIND if no region named "default" exists).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1507#comment:11>
