[GRASS-dev] GRASS extensions/addons mismatch
Martin Landa landa.martin at gmail.com
Wed Dec 14 20:37:54 EST 2011
2011/12/15 Michael Barton <Michael.Barton at asu.edu>:
>> it doesn't work to put GRASS_ADDON_PATH into .grass.bashrc,
>> you need to export it from your ~/.bashrc or ~/.profile.
>> (and it is too invasive to start appending to those automatically)
> It is not good to mess with these on the Mac unless you know what you are doing. That rules out most Mac users.
well, not only Mac-users ;-)
>> it needs to be set before init.sh/grass.py gets run.
>> my plan for trunk was to rename GRASS_ADDON_PATH (taken over
>> by g.extension.py) to GRASS_ADDON_BASE, then re-add
>> GRASS_ADDON_PATH as a $PATH component, if it exists. if it was
>> not already set then nothing is added to the environment.. it's
>> there if you want to use it, and not if you don't.
>> that does not preclude the wxGUI having a Preference setting
>> to add some dirs to the copy of the $PATH it maintains, starting
>> with any existing GRASS_ADDON_PATH enviro variable that was
>> there when it launched.
> All this is fine. However, GRASS_ADDON_BASE should not be a hidden file on a Mac. It is problem enough that preferences are there if you ever have to mess with them outside of the GRASS GUI.
There is no GRASS_ADDON_BASE. Anyway it should be controlled only by
`g.extension` (user scripts can live somewhere else). So basically
there is no problem that g.extension installs extensions to the hidden
directory.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
