[GRASS-dev] Re: [GRASS GIS] #226: WinGRASS fails to create .gislock
opening a mapset
trac at osgeo.org
Thu Dec 15 10:35:43 EST 2011
#226: WinGRASS fails to create .gislock opening a mapset
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Default | Version: svn-develbranch6
Keywords: wingrass, qgis | Platform: MSWindows XP
Cpu: All |
Comment(by glynn):
Replying to [comment:11 mmetz]:
> IIUC, the .gislock file is not created under windows because kill() does
not exist under windows, used by find_process().
Sort of. The existing code won't work in its entirety on Windows. As
Windows systems aren't generally multi-user, simply ignoring the entire
locking issue was the easiest solution.
> Under Linux, assume the following scenario: a group of people are
working from different machines on the same location, different mapsets.
The location is on a network drive accessible by everyone. Now g.mapset
mapset=othermapset using lock (GIS_LOCK) checks if it could kill the pid
written in .gislock. But if the pid in .gislock has been written by a
different machine/system, then the pid in .gislock has nothing to do with
the pid's available to lock, and the kill()-test is complete moot. Right?
The purpose of the kill() test is to check whether the .gislock file is
"stale", i.e. whether the session which created the .gislock file
terminated without removing it. If kill() fails with ESRCH, the PID stored
in the .gislock file doesn't refer to an existing process on the local
system, so the lock is assumed to be stale and is ignored. This test isn't
particularly reliable; it will consider the lock as stale if it was
created by a session on another machine, even if that session is still
alive, and will consider the lock as alive if the session has terminated
but its PID is now used by another process.
> Therefore I would suggest to skip the find_process() step and assume
that a mapset is locked as long as the file .gislock exists.
That would avoid the issue with the lock file being considered stale due
to having been created on a different system. OTOH, it would require stale
lock files to always be removed manually. If that is considered a problem,
writing a hostname along with the PID would solve the first issue without
abandoning automatic removal on non-shared filesystems.
Ticket URL: <http://trac.osgeo.org/grass/ticket/226#comment:12>
