[GRASS-dev] Re: [GRASS GIS] #226: WinGRASS fails to create .gislock opening a mapset
GRASS GIS trac at osgeo.org
Thu Dec 15 06:54:55 EST 2011
 Reporter:  msieczka        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.2
Component:  Default         |     Version:  svn-develbranch6
 Keywords:  wingrass, qgis  |    Platform:  MSWindows XP
      Cpu:  All             |
Comment(by mmetz):
 IIUC, the .gislock file is not created under windows because kill() does
 not exist under windows, used by find_process().
 Under Linux, assume the following scenario: a group of people are working
 from different machines on the same location, different mapsets. The
 location is on a network drive accessible by everyone. Now g.mapset
 mapset=othermapset using lock (GIS_LOCK) checks if it could kill the pid
 written in .gislock. But if the pid in .gislock has been written by a
 different machine/system, then the pid in .gislock has nothing to do with
 the pid's available to lock, and the kill()-test is complete moot. Right?
 In this case it would be more helpful if .gislock would not hold a pid,
 but the name of the user, e.g. user at host, currently accessing the mapset.
 Therefore I would suggest to skip the find_process() step and assume that
 a mapset is locked as long as the file .gislock exists. And always, also
 on windows, write the file .gislock.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/226#comment:11>
