[GRASS-dev] Re: [GRASS GIS] #226: WinGRASS fails to create .gislock
opening a mapset
trac at osgeo.org
Sat Dec 17 13:52:27 EST 2011
#226: WinGRASS fails to create .gislock opening a mapset
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Default | Version: svn-develbranch6
Keywords: wingrass, qgis | Platform: MSWindows XP
Cpu: All |
Comment(by glynn):
Replying to [comment:15 mmetz]:
> Displaying the PID and host to the user assumes that the user knows the
meaning of PID and host.
If they don't, they probably can't safely deal with a stale lock file.
On an unshared filesystem, the automatic resoluation via the kill() test
will usually work. The exceptions are where the PID has since been re-used
for an unrelated process (false positive), or if the shell itself has been
killed but child processes are still running (false negative). If they're
using a shared filessytem, there's probably some form of technical support
available.
> What about a windows user starting GRASS with msys and just killing the
msys terminal at the end, or not even bothering about the terminal.
If the session on that terminal is still "working" (i.e. not just waiting
for the next command), it's fairly important that they don't just start up
another session using the same mapset.
> Practice 1: single user single GRASS database
> * best practice would be to ignore a lock and proceed.
Note that this could result in a corrupted database. I don't know how
likely it is practice, i.e. whether it's common to have long-running
background jobs on Windows systems.
> The motivation behind displaying user at host is that most users would know
their user name and ideally the system (host) where they are currently
logged in. This (in addition to write permissions) should suffice to let
the user decide if he wants to try to remove a mapset lock.
They really need the PID in order to make that determination. Some people
have jobs which run for days. In a complex environment (where users have
accounts on several multi-user systems), it's not inconceivable that
someone can forget which jobs are running on which systems using which
mapsets.
In normal use, stale lock files shouldn't occur, so the presumption should
be that any existing lock file isn't stale. That presumption may be
overridden in the presence of additional evidence; e.g. if the PID
contained in the lock file doesn't refer to an existing process
(particularly if the lock file also contains a host and the host is the
local system), that tends to indicate staleness (the case where the shell
has terminated but child processes survive is rather hard to detect).
The solution to the problems with the existing mechanism should be to fix
it, e.g. by adding a Windows equivalent of the PID test, and adding the
host to the PID file. Rather than assuming that a lock file is stale
solely because the assumption is convenient, regardless of its accuracy.
Ticket URL: <http://trac.osgeo.org/grass/ticket/226#comment:16>
