[GRASS-dev] [GRASS GIS] #1518: Misunderstanding with different topology format
GRASS GIS trac at osgeo.org
Thu Dec 22 11:20:15 EST 2011
 Reporter:  lucadelu          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.2
Component:  LibVector         |     Version:  6.4.2 RCs
 Keywords:  vector, topology  |    Platform:  All
      Cpu:  Unspecified       |
 If you imported a file with GRASS7 and try to do some analysis with GRASS6
 it return the following error:
 ERROR: Topology format version 5.1 is not supported by this release. Try
 to rebuild topology or upgrade GRASS.
 For my point of view it isn't clear that the problem is related to GRASS7,
 because the words "version 5.1" are misleading. I suggest to change the
 error string with something more clear.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1518>
