[GRASS-dev] Re: [GRASS GIS] #1527: vector projection over wrapping
boundary is split
trac at osgeo.org
Sat Dec 31 12:26:36 EST 2011
#1527: vector projection over wrapping boundary is split
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment(by pertusus):
A select doesn't cross the boundary. Only the eastern part is selected.
I do a grid on the world map and select it by the Lambert map. I have
attached a tarball bug_grass_proj_wrap_select.tar.gz to reproduce. The
difference between the Lambert map and the selected world map grid may be
seen by comparing world.png (the Lambert map) and selected.png (the world
map grid selected).
The bug_grass_proj_wrap_select.tar.gz also shows the issue mentioned above
on the missing visible centroids in the world image. I guess that both
issues are related.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1527#comment:7>
