[GRASS-dev] GRASS-dev] 6.4.1 blocker bugs?
Michael Barton
Michael.Barton at asu.edu
Tue Feb 1 22:39:50 EST 2011
Martin,
Thanks for the quick work. I'm at home now and am able to test this. I updated to GRASS 6.4 release branch r45278 and compiled. No errors.
I've just tested the raster common import dialog.
The dialog is no longer modal and now it recognizes different file types (at least *.tif and *.png). A big improvement.
There are several things left to do on this.
1) I still cannot find where I can have it create a new location for a file I'm importing in a different projection from the one I'm in.
2) There is no way to specify a new name in GRASS for the imported file; it will only use the existing file name.
3) The load settings combo box does not work.
4) Clicking the "import" button closes the dialog, regardless of what happens. If there is an error or you want to load more than one file, you must reopen the dialog and browse to the file again.
I think that all of these affect the vector version too. So if it is a common wxDialog instance, then fixing it for raster should fix it for vector too I hope.
Cheers
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 1, 2011, at 9:37 AM, Martin Landa wrote:
> 2011/2/1 Michael Barton <Michael.Barton at asu.edu>:
>> the fact that the dialog is modal
> done in r45278.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
