[GRASS-dev] Re: [GRASS-SVN] r45267 -
grass/branches/releasebranch_6_4/locale/po
Markus Neteler
neteler at osgeo.org
Wed Feb 9 04:20:39 EST 2011
2011/2/8 Maciej Sieczka <msieczka at sieczka.org>:
> I find it easier to edit a po file when a single message is 1 line
> rather than 2 or 3, and when the number of lines in msgid matches the
> number of lines in msgstr. It also helps (me, at least) when comparing
> and merging po files from different branches and sources visualy (e.g.
> with meld).
> For a test I have formatted graslibs_pl.po in 6.4 to use as little line
> breaks as possible (although empty '""' msgid's and msgstr's are just a
> clutter, there's no point in removing them too, because they would
> re-appear after next msgmerge, even with --no-wrap, anyway). Are there
> any objections if I do the same for remaining *_pl.po files?
> @Markus: May I also suggest using msgmerge in po_merge.sh with
> --no-wrap, if that doesn't pose problems I'm not aware of?
Sure, we can use --no-wrap always if that helps (and works)!
Markus
