[GRASS-dev] recent updates to Vlib break vectors in GRASS 7
Barton Michael
c.michael.barton at gmail.com
Sun Jan 2 19:16:55 EST 2011
Will this be difficult to fix?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 29, 2010, at 4:32 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> I suspect it's because r44722 added gprojects.h to Vlib, in particular
>> that open_ogr.c where Michael got the error.
> Erm, yeah. That's sounds like the most likely explanation.
>> There are a lot sources in
>> vlib, so I didn't check if any others included gprojects.h indirectly.
>> So, the question then: add PROJINC to VECT_CFLAGS (for all vector stuff)
>> or to the vlib makefile only?
> Vlib/Makefile only.
> The reason for VECT_CFLAGS is that vector.h includes geos_c.h and
> vect/dig_structs.h includes ogr_api.h, so *anything* which uses those
> headers needs the appropriate -I switches or an error will occur, even
> if the module doesn't actually use the structure or function
> declarations which use the OGR/GEOS types.
> But simply including the vector headers doesn't pull in the PROJ
> headers, so there's no need for VECT_CFLAGS to contain $(PROJINC).
> Ideally, -I switches (and to a lesser extent, -L switches) should be
> kept to a minimum; the more directories in a search path, the greater
> the chance of encountering conflicting file names.
> Glynn Clements <glynn at gclements.plus.com>
