[GRASS-dev] wxGUI: close dialog on finish by default
Martin Landa
landa.martin at gmail.com
Mon Jan 3 09:34:06 EST 2011
2011/1/2 Helmut Kudrnovsky <hellik at web.de>:
> since r44668 is "wxGUI: close dialog on finish by default" all wxgui-dialogs are closing after finishing the command.
> at least for v.info, r.info it would be reasonable not to close the wxgui-windows immediately.
in r44830 is 'close' checkbox generated only for commands which have
some output (at least one parameter with `age == new`. The option is
checked by default. Can be change in the preferences.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
