[GRASS-dev] Re: [GRASS GIS] #1251: tweaking new feature in file
selection drop-down of layer manager
trac at osgeo.org
Mon Jan 3 10:43:04 EST 2011
#1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: martinl
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: map selection
Platform: Unspecified | Cpu: Unspecified
Comment(by cmbarton):
The bug I reported has indeed been fixed. Thanks much. I'm not sure
whether we want to keep this open as an enhancement request or not.
Testing on GRASS 7 (svn trunk updated 2 January 2011), the drop down
search feature works as follows on my Mac.
Click to display map list -> all maps are displayed and user can select
any map
Type something while map list is displayed -> nothing happens
Type something while map list is closed, then click to display map list ->
all maps are displayed and the selection indicator is located on a map
that begins with the same characters as those typed (if such a map
exists).
So AFAICT, there is no filtering, but there is an easy (if not obvious)
way to quickly move the selection cursor to a desired map in a long list.
Is this behaving the way it is supposed to behave?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:9>
