[GRASS-dev] Re: [GRASS GIS] #1251: tweaking new feature in file
selection drop-down of layer manager
trac at osgeo.org
Mon Jan 3 11:33:36 EST 2011
#1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: martinl
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: map selection
Platform: Unspecified | Cpu: Unspecified
Comment(by annakrat):
Replying to [comment:9 cmbarton]:
> Type something while map list is displayed -> nothing happens
Sorry, I tried to change this behaviour but unsuccessfully, there are some
problems with events. So it's necessary to close the popup to type
anything.
There are some other features you haven't described, you can display popup
with down arrow. Then it's possible to change selection with arrows, tab
changes selection to map (starting with typed letters) in the next mapset,
enter confirms the selection and closes the popup. Don't be surprised that
the action is performed after releasing the key (and not pressing down),
it's the same problem I mentioned before.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:10>
