[GRASS-dev] [GRASS GIS] #1254: v.extract and v.build errors
trac at osgeo.org
Mon Jan 3 11:35:49 EST 2011
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.build, v.extract | Platform: Linux
Cpu: x86-32 |
Recent changes have turned v.extract and v.build erroneous. [[BR]]
r44825:
v.extract input=cd78refl at CHRIS type=area list=3882 output=tmpa --overwrite
[[BR]]
ERROR: Vector map <cd78refl at CHRIS> not found
Vector map of non-overlapping polygons cd78refl is present, can be
displayed, and has the polygon of category 3882. [[BR]]
Output of v.info:
v.info map=cd78_refl at CHRIS layer=1 [[BR]]
Mapset: CHRIS [[BR]]
Database: /home/grass [[BR]]
Title: Output from v.patch [[br]]
Map scale: 1:1 [[BR]]
Map format: native [[BR]]
Type of map: vector (level: 2 [[BR]]
Number of points: 0 [[BR]]
Number of lines: 0 [[BR]]
Number of areas: 4503 [[BR]]
Number of centroids: 4479 [[BR]]
Number of boundaries: 4509 [[BR]]
Number of islands: 4503 [[BR]]
Map is 3D: No [[BR]]
Number of dblinks: 1 [[BR]]
v.build causes segfault:
kernel: v.build[20509]: segfault at 2c ip 0804922b sp bfaaa050 error 4 in
v.build[8048000+2000]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1254>
