[GRASS-dev] GRASS 6.4.1 testing
Helena Mitasova
hmitaso at unity.ncsu.edu
Wed Jan 5 19:51:15 EST 2011
so far everything goes well except for
Add shaded relief map
run from wxgui - it says
Warning
Map <elevation_shade at PERMANENT> not found
but it runs when the relevant command
d.his h_map=elevation i_map=elevation_shade
is pasted into command console
Helena
On Jan 5, 2011, at 12:25 AM, Barton Michael wrote:
> Just did an update from the svn release branch this morning and am testing GRASS 6.4.1
> There is a piece of left over testing code in toolbox.tcl from v.digit (line 55) that puts the button number to the screen. Can I just remove it and commit or do I need to do something special with respect to RC1?
> Also, it seems like the tcltk digitizer is not making areas. I can create the boundary and add a centroid, but it does not turn into an area when saved. Perhaps I'm missing something here and someone else might want to test this.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
