[GRASS-dev] GRASS 6.4.1 testing
Martin Landa landa.martin at gmail.com
Thu Jan 6 05:18:10 EST 2011
2011/1/6 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> Add shaded relief map
> run from wxgui - it says
> Warning
> Map <elevation_shade at PERMANENT> not found
> but it runs when the relevant command
> d.his h_map=elevation i_map=elevation_shade
> is pasted into command console
fixed in r44896. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
