[GRASS-dev] GRASS 6.4.1 testing
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Jan 6 23:42:03 EST 2011
Martin,
thanks for the quick fix - I found few more instances of a similar problem:
d.grid runs from command console, when trying to add it through the GIS manager
it says Map <grid> not found
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30 runs from command console
but when running it through GUI Add RGB... it cannot find the maps
Search module > Import vector data > common import formats fails to open GUI panel,
when run from GIS manager it opens GUI panel properly
same for Import raster data in common formats
GUI for raster import does not see .img for Erdas Imagine images (img files are grayed out),
it runs OK through the command dialog
Helena
On Jan 6, 2011, at 5:18 AM, Martin Landa wrote:
> Hi,
> 2011/1/6 Helena Mitasova <hmitaso at unity.ncsu.edu>:
>> Add shaded relief map
>> run from wxgui - it says
>> Warning
>> Map <elevation_shade at PERMANENT> not found
>> but it runs when the relevant command
>> d.his h_map=elevation i_map=elevation_shade
>> is pasted into command console
> fixed in r44896. Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
