[GRASS-dev] GRASS 6.4.1 testing
Martin Landa landa.martin at gmail.com
Fri Jan 7 05:02:13 EST 2011
2011/1/7 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> d.grid runs from command console, when trying to add it through the GIS manager
> it says Map <grid> not found
> d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30 runs from command console
> but when running it through GUI  Add RGB... it cannot find the maps
these issues should be also fixed.
> Search module > Import vector data > common import formats fails to open GUI panel,
> when run from GIS manager it opens GUI panel properly
> same for Import raster data in common formats
Seems to work on my machine. Can you post the traceback to ML?
> GUI for raster import does not see .img for Erdas Imagine images (img files are grayed out),
> it runs OK through the command dialog
Seems to work, choosing file/directory and format 'img', the files are
loaded properly.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
