[GRASS-dev] GRASS 6.4.1 testing
Helena Mitasova hmitaso at unity.ncsu.edu
Mon Jan 10 21:17:35 EST 2011
On Jan 7, 2011, at 5:02 AM, Martin Landa wrote:
> Hi,
> 2011/1/7 Helena Mitasova <hmitaso at unity.ncsu.edu>:
>> d.grid runs from command console, when trying to add it through the GIS manager
>> it says Map <grid> not found
>> d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30 runs from command console
>> but when running it through GUI  Add RGB... it cannot find the maps
> these issues should be also fixed.
>> Search module > Import vector data > common import formats fails to open GUI panel,
>> when run from GIS manager it opens GUI panel properly
>> same for Import raster data in common formats
> Seems to work on my machine. Can you post the traceback to ML?
here it is ( same error also for DXF, E00, and for raster for common formats,
everything else works)
> Traceback (most recent call last):
>   File
> "/Users/Shared/src/GRASS/grass-6.4.1RC1-snow/dist.i386
> -apple-darwin10.5.0/etc/wxpython/gui_modules/ghelp.py", line
> 311, in OnItemActivated
> self.OnRun(None)
>   File
> 287, in OnRun
> eval(handler)(event = None, cmd = data['command'].split())
> TypeError
> OnImportOgrLayers() got an unexpected keyword argument 'cmd'
Helena
>> GUI for raster import does not see .img for Erdas Imagine images (img files are grayed out),
>> it runs OK through the command dialog
> Seems to work, choosing file/directory and format 'img', the files are
> loaded properly.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
