[GRASS-dev] Re: [GRASS-SVN] r44977 - in grass/trunk: gui/wxpython/xml imagery imagery/i.evapo.PT
Martin Landa landa.martin at gmail.com
Wed Jan 12 10:48:07 EST 2011
2011/1/12 Yann Chemin <yann.chemin at gmail.com>:
>>> yeah no problem to move to small caps, initial reason was that it was
>>> Family names abbreviation...
before adding new and new modules I would really like some discussion
on ML if the module needs to be in trunk. E.g. at least most of
modules which you have added recently breaks syntax convencion, eg.
1) don't use caps in module name
2) missing keywords
3) Flag's description should start with caps
4) Completely strange parameter names, besides caps again.
I'ts just subset, unfortunately...
Martin
Description:
 Evapotranspiration Calculation Prestley and Taylor formulation, 1972.
Usage:
 i.evapo.PT [-z] RNET=[W/m2] G0=[W/m2] TEMPKA=[K] PATM=[millibars]
   PT=[-] output=[mm/d] [--overwrite] [--verbose] [--quiet]
Flags:
  -z   set negative ETa to zero
 --o   Allow output files to overwrite existing files
 --v   Verbose module output
 --q   Quiet module output
Parameters:
    RNET   Name of Net Radiation raster map
      G0   Name of Soil Heat Flux raster map
  TEMPKA   Name of air temperature raster map
    PATM   Name of Atmospheric Pressure raster map
      PT   Prestley-Taylor Coefficient
           default: 1.26
  output   Name of output Evapotranspiration layer
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
